  1. Member vhelp's Avatar
    Mar 2001
    New York
    [img][/img] tags are not working. Instead, all the images are displaying in one area at the bottom of the post. And, if possible, can someone fix the images in my post to show under their tags ? thank you.
    see my thread #4 for an example:
    https://forum.videohelp.com/threads/315629-WinTV-HVR-2250-Model-1213-first-impressions-...ulty?p=1953612
    -vhelp 5313
    canada
    I saw the images,i'll post what i saw to see if it appears here for you.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I can see them here as well
    Read my blog here.
    I will fix so you can make customs img tags for your uploads later.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Or instead, click on the insert image link( , above the text post area ) and upload the images from there.
    Test image above
    Test the posting of image
    update -- yep, vB 4 is same as vB 3.x
    It's the same as this: http://www.digitalfaq.com/forum/showthread.php/properly-upload-images-1529.html
    Use the paper clip, and it adds
    and then it shows the attached image to usergroups with permissions to see the attachments.
